Another Overheating thread..... I know
Rep Power: 0 Another Overheating thread..... I know
I know this has been talked about before. Ive searched and nobody hasnt encountered the same problem I think.
Anyway 2 days ago my JDM D15 Del Sol temperature passed the halfway mark and it was surly going to the H mark.
Luckily I arrived home just in time. I checked the radiator, hoses and everywhere for leaks. I didnt find anything. No leaks at all and the radiator was full. I started the car and waited for it to heat up. The fan didnt kick in so I got a radiator fan switch and put it on. The fan still didnt start so I jumped the wires and drove around the block with the fan jumped and it still began to overheat. While I was driving I had to turn on the heat so that will lower the temp which it did instantly.
The radiator and cooling system was flushed a month ago and this just happened to start. I have playing around for at least a few hours to see if it was an electrical fault but the fuses and relays are fine. I don't have a clue what to do next.
So basically my fan isnt working with the new switch installed, the radiator and the system was flushed out a month ago and I surely cant use the AC
Im out of ideas.
Im out of ideas.
Re: Another Overheating thread..... I know
With the radiator fan running and the engine getting hot, open the hood and put your hand behind the radiator fan and feel if it is blowing screaming hot air or if it is blowing somewhat lukewarm air, or what it's blowing.
Possible thermostat stuck closed, possible clogged radiator core ----either clogged inside so it has poor water flow, or clogged on the outside with 20 years of sand and bugs so it has poor air flow---, or something along those lines.
One time I found a plastic shopping bag somehow got stuck between a radiator and AC condensor blocking all air flow..... I didn't find it until things were being taken apart.
solarpunk70
04-12-2016 11:43 AM
raymondxcho
09-29-2015 09:00 PM
tooly145
09-05-2015 01:05 AM
