1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Idle problem and code throwing
Old 04-08-2011
rbrennan's Avatar
rbrennan is an unknown quantity at this point
I have a 91 Civic CX and its throwing code eight at me which looks like TDC position Except the car starts fairly normally,but when I start it it will idle normally until the check engine light comes on,then it will start to idle at lower rpms almost like its running lean.It does not have a muffler on it and I drilled holes in the airbox and removed the tubing.Im just wondering if thats related,It did just get a new cap and rotor.And im also finding oil in the sparkplug holes.
rbrennan is offline
Old 04-08-2011
rbrennan's Avatar
Re: Idle problem and code throwing
Wow really?...no one?
rbrennan is offline
Old 04-08-2011
if its tdc code then i would try to replace that sensor first. for oil in spark plug holes, get a valve cover set with new spark plug tube seals.
gearbox is offline
sharp66
31
06-12-2022 08:45 AM
jbradley4809
04-07-2017 04:23 AM
oqjoi
Transmission
05-06-2015 06:27 PM
tylerginevan
04-27-2015 12:29 PM
Speedy
Idle Issues
12-14-2001 09:04 AM
Quick Reply: Idle problem and code throwing
