Need help with my car.
Rep Power: 0 Need help with my car.
Okay Problem with my car is that the timing belt keeps moving off the cam but it dosent come off and I have the belt on pretty tight but not too tight. Also when I start my car it well make a loud noise for a few seconds and it will go away and it will make the same sound while I'm driving. I would also like to add I just replaced the timing belt and the water pump. Any thoughts or ideas will be appreciated. BTW It's A 1.6 block with a Z6 Head,104 tooth timing belt.
1 Post
Rep Power: 165 Re: Need help with my car.
If the timing belt moves off the cam then you have 1 of 2 problems, incorrect tension or pulley alignment. Secondly you are going to have to be more specific about the sound, is it like a belt squealing, metallic grind, etc.
juror
Suspension DIY
07-30-2019 03:28 AM
JLee93
08-21-2015 05:44 PM
LorenzoC0395
07-14-2015 08:46 PM
