1992 Civic Hatch won't start....sometimes
Rep Power: 0 1992 Civic Hatch won't start....sometimes
I have a 92 Civic that starts and drives perfect. Every once in a while when I go to turn it over it just keeps turning over and over and over. It's like it isn't getting gas or spark or something. I keep pumping it sometimes it fires up and sometimes I have to get a couple guys to push so we can pop the clutch. Then the car is fine again. Anyone have any suggestions or experienced similar problems? Not sure if it needs cap, rotor and all that jazz. Or perhaps a fuel filter. I am just puzzled as to why it only does it on occasion. Thanks.
Rep Power: 0 Re: 1992 Civic Hatch won't start....sometimes
i have a 91 civic station wagon w/ the hatchback, that did that aswell for a wile. i put some fuel . it was Pro-Gard/12 oz. fuel injector cleaner. it seemed to fix it becouse my car dont do it anymore.
check ur main relay switch cuz that just happened 2 mine n now its fixed but if u really wanna make sure it is take a piece of wire n stick it in the 5n7 slots n jump the relay 2 make sure that that is ur problem
sounds like what mine was doing a while ago. My problem was the ignition. I changed my plugs, wires, cap and rotor (along with the msd external coil just for fun) and havent had that problem ever again. But before you do all that, spray some wd40 on both ends of your plug wires for a better connection. Its a great temporary fix.
What is the main relay and where's it located?
Mine has same 'not starting' issue, more not than starting right now. Has anyone heard of the issue being in the ignition switch?
Have changed out distributor, distributer cap, fuel pump and the main relay. When it doesn't start, the fuel pump won't pump, can't get it out of park-brake isn't allowing and the check engine light doesn't go off. When it gets started it runs great!
Low and slow!
1 Post
Rep Power: 190 Re: 1992 Civic Hatch won't start....sometimes
SSMatey
04-13-2015 06:09 PM
