1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
'93 with Cold Automatic Transmission troubles
Old Jan 5, 2014
JamieClay's Avatar
JamieClay is an unknown quantity at this point
I've got a 1993 Civic Del Sol (love it) - it has 130k on it and for the most part the automatic transmission works well, except on cold mornings.
Until it warms up it will not shift out of first gear. When it is behaving in this manner there is a siren like wining of gears that increases as you attempt to go faster.
While at speed, if you put the transmission into neutral the sound continues at the same level so it's connected to the vehicle speed, not engine.
Once the transmission has warmed up enough, it will make a chuncking sound not unlike synchronizers meshing on a standard transmission and once the 'chunk' noise occurs the transmission will shift normally.
If I let the car warm up first, I will not encounter this issue.
Here is a link to the sound if you want to hear it.
I've checked fluid levels, the fluid was changed probably 30k ago if I recall correctly.
Any suggestion / tips appreciated!
RIPSAW
Nov 6, 2015 04:36 AM
tock172
Jun 22, 2015 09:37 PM
vtecbrah
May 31, 2015 01:24 PM
cruisers10
May 12, 2015 10:46 PM
alexkharden
Apr 23, 2015 07:13 PM
