1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Looking to do a GSR swap for 95 Civic
Old Dec 4, 2009
Xhondatech's Avatar
Xhondatech is an unknown quantity at this point
Title says it. I was wondering if anyone could help me out with what i need for this. I wanna use a B18c1 with a Type R trans. For now until i get the supercharger. I know this is what ill need. Fully Assembled Engine, Trans, ECU, Clutch, Axles Motor Mounts, Obviously the wiring harness. Do i need to change out the hubs for the GSR axles to fit? I wanna get my list together before i buy anything. So i can make this as easy as possible as i have never done a swap before. Im sure i could figure it out just looking for second and third and fourth opinions and so on. Thanks for any help anyone can give me.
Old Dec 5, 2009
YSIDRAG's Avatar
YSIDRAG is an unknown quantity at this point
Re: Looking to do a GSR swap for 95 Civic
It looks like you have it coverd for the most part. The teg axles are what you will need to use.
Jay
Fabricated Performance
Old Dec 16, 2009
Xhondatech's Avatar
Will those axles work with the factory hubs that are in the car?
Old Dec 19, 2009
thats pretty much the best vtec motor you can have, it will bolt in no problem but you will need to do some fabbing for limited slip transaxle.
Old Dec 21, 2009
Xhondatech's Avatar
One thought that i had....will i have to swap out the fuel pump too? Im sure the GSR engine uses more fuel then the D16 thats in it. Im hopin this swap takes me a weekend to get right. Ill post pics as i go along too. Oh and what am i gonna have to do for the LSD? For the time being i was gonna put the Type R trans in it until i got the Jackson for it. Doesnt the Type R have an LSD already?
Old Dec 21, 2009
i havent done the swap so i cant give specific details, but makes sense about the fuel pump. you may want to see what the pressure is on the D16 fuel line and compare that after the swap. theres a chance it will run just fine, since alot of those systems are designed to run much higher than they actually need to. just face each problem as it comes.
Old Jan 10, 2010
Xhondatech's Avatar
Yea i guess ill just have to take the issues as they come up. The fuel pump isnt my biggest concern..its the axles. I wonder if the GSR axles will work with the stock splines in the hub. And now im considering doing a type r swap cuz i get the type r swap for about the same as the GSR. So nows it the type r axles im worried about. If anyone has done a swap let me know what the deal is. I think the 8lb jackson kit comes with a fuel pump for the setup. So thats covered i just gotta figure out some other stuff. Thanks
Old Jan 11, 2010
JDM_Ricer's Avatar
JDM_Ricer is an unknown quantity at this point
The axles depend on the year you get.. 94-01 will work with the stock civic wheel hubs..
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
usajags84
May 10, 2015 08:11 AM
Rinzlor
Apr 24, 2015 10:33 AM
shawe90
Apr 14, 2015 07:10 PM
Desi
Nov 14, 2001 01:58 PM
