97 civic ex belts and leaking power steering pump
Rep Power: 0 97 civic ex belts and leaking power steering pump
Hello I have been fixing leaks on my 97 civic ex seems lastly a leak from the power steering pump itself may be occurring, I am curious because at this point I am more concerned that the vehicle just runs properly then has power steering, I am concerned thAt the fluid can get into the belts pulleys and on gaskets,my question is if I I remove a\c belt and power steering belt will this cause any damage to the pump or pulleys? Other than them not functioning can any damage occur by doing this? I really just want to put on a new alternator belt and pulley and just drive it dry without any leaks or worries this winter, been long costly projects everything to do with the pump costs money i don't have thank you
Re: 97 civic ex belts and leaking power steering pump
Install a Seal kit for the pump?
Or replace whatever seal is leaking?
Junkyard pump?
Junkyard pump?
JuNiOrTs
10-11-2016 12:15 AM
gogolf0401
09-02-2014 09:05 PM
BlueEM2
12-08-2009 10:48 PM
