Honda civic 1996 engine swap
Rep Power: 0 Honda civic 1996 engine swap
So i got a 2000 civic matching my 1996 honda civic dx couple mechanics say its compatible with using my vin number and model of car etc is there any other components ill need to make the swap successfull?
Received 1,126 Likes
Rep Power: 191 Re: Honda civic 1996 engine swap
so what engine is it?
if it's a non vtec engine (d16y7) then it will just drop into your car no problem
if its vtec (d16y8) then you can just put the whole thing in and just not hook up the vtec.
or put your old head on the new block and drop that in
so as long as it the same engine, and you're only changing the engine and not swapping auto to manual or vice versa then it should work no problem.
if anything on the new engine doesn't match the old engine (they may have changed the design of a sensor or something) just take it off the old engine and put it on the new one
xJt
06-19-2019 10:59 AM
crytikall
06-04-2011 08:29 PM
