Shifting issues on1998 civic with automtic
Rep Power: 0 Shifting issues on1998 civic with automtic
per the forum I’ve done a 3x3 tranny flush but still have the same issue. Can’t decide what gear to stay in at cruising speed. I’ve heard next step is to remove solenoids and screen and clean with Brake clean. Can someone tell me what this involves or direct me to a link please!
Re: Shifting issues on1998 civic with automtic
CEL on? Flashing D light? Got fault cods?
Check TPS operation?
Rep Power: 0 Re: Shifting issues on1998 civic with automtic
Problem is it drives great one day the next day it fails. No CEL no flash D nothing!
Faults like this , at cruising speed 45-70 let’s say, it can’t decide what gear to stay in ( or to lock convert or) if that even applies, don’t know much about this animal.
On flat ground, no change in load or pedal pressure, it will jump back and forth. Tach will read 2800, then 3100, back and forth. Will go away and then maybe come back. Some days it does great.
Fairly well maintained car, seems to perform well engine wise, 200K miles 1.6 motor.
HELP !!
HELP !!
So it's not actually changing gears *****-nilly, that would be a huge obvious RPM change.
2-300 rpm variation at steady speed is probably TCC locking/unlocking/slipping, and with the mileage on the unit it wouldn't surprise me if it's got a lot of wear, causing the issue you describe. Eventually if it stays unlocked when it should be locked, at the right road speed (50-60 mph) long enough it might set a fault code P0740.
I might want to monitor the TPS voltage just to see if it's changing (flaky sensor doesn't hold steady voltage even though throttle position is steady)
and run it/drive it with a scanner connected and showing live data list, looking for anything unusual in the data, but not holding my breath.
Consider excessive drag might aggravate it, like low tire pressures or oversize wheels and tires, or overloaded with extra weight
Thanks for the response. Never seen any codes set, well it has set Hi- temp a couple times, should not be any drag issues. Car is bone stock, bought it few months back from a lil ol lady. I’m second owner. All is well in drive line wheels etc.
your probably right about it being TC
Question can I disable an input or wire and prevent it from locking? To see what it does. I will check TPS with scanner. Odd that this issue is intermittent!!
There is a tsb for checking the o ring on the snout of the torque converter, if it is damaged or missing it can cause the code (IIRC this was more of an issue when there was a problem with a recent trans replacement)
You can pull the TCC solenoid set and CPC solenoid off and look for those tiny screens to clean out
Aaaaand since hot fluid exits the converter and goes to the atf cooler, what happens if that cooler has become a bit restricted? Could that cause TCC to act funky? (wondering out loud here)
Plus anything that could go wrong with the valve body inside the trans.....
wl thanks again. I was just looking for a way to narrow this down a little (disabling TC). Just odd it is so intermittent. Just drove it 15 miles down the highway and it was failing miserably at cruising speed, 2 hours later I drive home and it’s fine😆
I’ll check TPS tomorrow. Do you think if I find nothing there. Pull solenoids and check screens?
Pzern
07-20-2018 07:40 PM
winanthony94
09-25-2015 09:05 AM
NV00EX
03-15-2013 06:56 AM
