Honda civic 1996 obd2 connector
Rep Power: 0 Honda civic 1996 obd2 connector
Greetings
can any one will help me here to guide me the obd2 connector location in Honda civic 1996 ? I bought a 16 pin mini Bluetooth scanner blue color
Rep Power: 0 Re: Honda civic 1996 obd2 connector
Hello colin42 thank you for your response
I can't find it under the dash near kick panel on driver side.
Do you got any picture of it so that might be easier for me to find it out . Thank you again 😀
Just feel around under the dash near the driver's side. Look for the small panel for the fuses. You don't need to remove it to get to the OBD port, but it guides you to find it. The port is pointing DOWNWARD.
Ha! Colin beat me to it and has a better pic too. Right on Colin
Check this vid out: (it helps a bit)
Thanks a lot colin42 for your quick response and a big help
surely I will go and check the connector in my car .
shortly I will get back you 😀😀
Thank you
Regards
Thank you
Regards
Honda used to print the DLC location on a label on the bottom of the steering column covers.
Thank you ezone for your response
I guess I don't have this port in my car .
I have removed right side kick panel even left side kick panel but I was unable to find it . My car is make in Japan but imported to United Arab Emirates
Thank you jorily the picture you posted it's a brand new car . And I have enquired about Honda civic lxi 1996 dosent has obd2 port . Thank you anyways
[/QUOTE]
[/QUOTE]
secur60
01-05-2018 11:40 AM
roverben
02-26-2015 10:56 PM
