OBD II reader unable to link to check my check engine light
Old 06-22-2018
Tx_roadkill's Avatar
Tx_roadkill is an unknown quantity at this point
Took my car to O’Reilly to see what my engine codes were but both code readers he tried would not link up to my car.
Anyone else had had this issue?
Tx_roadkill is offline
Old 06-22-2018
Colin42's Avatar
Received 1,126 Likes on 941 Posts
Re: IBD II reader unable to link to check my check engine light
Fuse? Damaged connector?
Colin42 is offline
Old 06-22-2018
I checked every fuse and the connector looks good. I’ll check deeper. Maybe a wire pulled out or is broken.
Just wondered if anyone else else had this issue.
Old 06-22-2018
What DID the code reader say or do?
Won't power up at all?
Powers up but says no communication?
I assume you want to check codes because the CEL came on...What symptoms does the car have?
ezone is offline
Old 06-22-2018
it said unable to link.
Had CEL on. Code reader said O 2 sensor was bad. Replaced the broken exhaust manifold with a header and replaced both O2 sensors and muffler.
CEL took longer to illuminate but when it did I took it straight to O’Reilly and they said it cannot communicate with the car.
Took it today which is 2 weeks later hoping it would read but did not.
Old 07-01-2018
Thanks for everyone’s help.
I checked all the wires and components for damage and everything was fine. Took it to O’Reilly and it was able to read it. Maybe it just needed a little wiggle. Now I have to see why it’s popping up a code for the O2 sensor. I just replaced them both when I installed the new header.
Old 07-01-2018
What's the code number?
ezone is offline
Old 07-01-2018
Re: OBD II reader unable to link to check my check engine light
p0141
JesusWoreNikes
05-23-2018 07:19 PM
Akdutta
01-06-2018 10:48 AM
Payton
10-07-2012 01:25 PM
oscar meza
18
05-05-2009 03:37 PM
axekid07
10-01-2006 09:20 AM
Quick Reply: OBD II reader unable to link to check my check engine light
