Nitemare over heating. Out of ideas
Rep Power: 0 Nitemare over heating. Out of ideas
I bought this 99 LX for $800 thinking I was getting a decent work car. I didn’t really check it out other then starting it up and ran great. Later I found out it over heats and after looking more into it I see the heater core was bypassed and the thermostat was removed as well as the coolant fan jumpered to run all the time. I drove it a few times to get it home and had to stop it to cool down and start several times. Anyway after reading a lot of articles and doing more checks I decided to replace the head gasket thinking that combustion was getting into the coolant. Well the gasket was new as well as was the timing belt and water pump. I’m stumped. Only thing I can think is the head and or block may be bad? I have pics of the head and the block. The head seems flat and don’t see any cracks but realize it still may be. The block surface looks suspect and there looks to be corrosion on the outside of cylinder walls and the coolant has white substance too. If it needs an engine that I’ll prolly just part it out but if y’all think I can maybe replace the head gasket again and maybe help me with something I’m over looking. It runs great tho which don’t make sense. Sorry so long but please help.
Block right after I removed head and before I cleaned surface.
White substance in coolant.
More of the corrosion.
Trying to get a shot of the ugly looking coolant and corrosion.
Corrosion I assume. I removed that piece.
Head surface after I cleaned it. Looks good from what I see.
#4 cylinder is chipped as well.
#3 cylinder. Looks like a chip in it.
Received 1,120 Likes
Rep Power: 190 Re: Nitemare over heating. Out of ideas
that looks like some idiot put stop leak in there,(or maybe used tap water)
you're probably going to have to replace the rad, heater core, some hoses, and anything else coolant touches that you cant get clean, all the water passages in the block need to be cleaned, there might even be chunks stuck in the water pump and thermostat
Rep Power: 0 Re: Nitemare over heating. Out of ideas
What’s the best way to try and clean all that? Them deposits are pretty solid. Have you ever seen one this bad? I’m worried that I might not be able to clean it good enough.
Wow that is cheap. I don’t know if it’s worth the money and work at this point. Is there any chemical that I could put into the system that would help losses this stuff up?
Prelude Owner
You should get the head checked at a shop for flatness. It may look flat but it takes very little variance to cause an issue. That could be why the repair never worked.
I have used ATF and vinegar to clean carbon, rust and general gunk with great results.
Yes that’s the gasket that was on it. It’s brand new. The previous owner replaced a lot of things trying to fix the over heating issue it appears.
People typically bypass the heater core when it leaks. I would try to go back and add the thermostat and fix the electric fan back to original. Did you verify that coolant was flowing through the system properly? Water pump circulating the coolant? Hoses getting hot? Is there air trapped inside the system? There is a great tool to put on radiator to make sure all air is purged out when running the engine. May need to run a chemical flush as well. Any coolant getting into your oil?
Slicer1989
21
03-20-2018 05:21 PM
mikey1
16
01-27-2014 04:17 PM
gogolf0401
09-28-2012 04:48 PM
delliott101
08-19-2010 04:49 PM
twizted91gt
02-19-2006 12:48 PM
