Removing a crank pulley bolt with Milwaukee M18
I'm going to be doing a timing belt. Has anyone used a Milwaukee M18 fuel 3/8 impact to successfully remove the pulley bolt?
Re: Removing a crank pulley bolt with Milwaukee M18
The only way it will come out with a 3/8 gun is if the last person who had it apart didn't tighten the crank pulley bolt properly.
You will need bigger tools.
Rep Power: 0 Re: Removing a crank pulley bolt with Milwaukee M18
my craftsman 1/2 impact C3 is rated at 200 foot pounds i believe... your pully at max could be about 145.. it would be a cool video you should upload the attempt.
And breakaway torque is far higher than initial tightening torque.
i just did a quick search for the 6th gen spec.. i cant wait to see if my craftsman can spin my pulley bolt off..lol for some reason theres no timing covers installed.
Received 1,148 Likes
Rep Power: 485 Re: Removing a crank pulley bolt with Milwaukee M18
I read somewhere that the torque value for some civics is 181ft-lbs. D17 says 14 ft-lbs + additional 90 degrees. This past time, I sheared the tip of one of my 3/8" socket extensions breaking the crank pulley bolt loose
Prelude Owner
3/8 won’t touch it. 1/2” minimum and 3/4” would make it easier.
Took me impact rated extensions, sockets and 6ft pipe. Also crank Tool helps imo.
