P0122 tps
Rep Power: 0 P0122 tps
I have a 2000 EX D16Y8 5-speed and I recently had low idling problems. I did research and changed the throttle position sensor and the low idle stopped but now it seems kind of high (around 1200-1500) I have also erased the P0122 code multiple times but it keeps coming back. Does this have anything to do with the high idle or what is the issue? Thanks.
Re: P0122 tps
Sounds like the TPS is misadjusted. Get a scanner that shows live data.......adjust TPS while reading voltage output on a scanner live data display....set to 0.49v@closed throttle.
Then clear codes, disconnect battery, wait several minutes with doors open, reconnect battery, start and warm up engine, relearn idle.
Rep Power: 0 Re: P0122 tps
