2002 civic bogs down after driving awhile HELP!
Rep Power: 0 2002 civic bogs down after driving awhile HELP!
my 2002 civic bogs down after driving awhile won't get over 50 and will die sometimes,sooner if it's hot out or if you drive or 75mph for a bit.its happen sooner and sooner now. if it sits a little bit hour or so start and runs good again for awhile. please help!!
Rep Power: 0 Re: 2002 civic bogs down after driving awhile HELP!
also burn gas like crazy when it does this
Replace the Fuel Filter / Replace the Fuel Pressure Regulator / Clean the Fuel Injectors manually remove them / replace the seals / filters
Replace the Fuel Filter / Replace the Fuel Pressure Regulator / Clean the Fuel Injectors manually remove them / replace the seals / filters / Replace & Check spark plugs / wires...???��bigfoot
