Does a 98 civic ex 2door have hydraulic valve lifters?
Rep Power: 0 Does a 98 civic ex 2door have hydraulic valve lifters?
My mechanic says I have a "bad lifter" causing clacking and grinding noise. I brought it in after the noise began 2000 miles after a head surface/gasket replace and timing belt job. It sounded to me like the grinding was coming from under the timing cover- wanted to see if it was an issue covered by the parts and labor warranty. I'm concerned they are being dishonest.
Received 1,122 Likes
Rep Power: 190 Re: Does a 98 civic ex 2door have hydraulic valve lifters?
find a new mechanic, there are no lifters, the rocker arms on the cam contact the valves. and you might want to check the timing belt and tensioner before you drive the car if there's strange noises coming from it.
Rep Power: 0 Re: Does a 98 civic ex 2door have hydraulic valve lifters?
Yeah that's what a little cursory research is suggesting. Any advice for trying to get an unscrupulous mechanic to honor a labor/parts warranty? It also may be that I talked to the service writer and he misinterpreted something the actual mechanic said. It's a well reviewed, professional-seeming shop.
No.
Cam follower or rocker arm might be a more correct term?
Could be the valve lash clearances aren't correct, maybe someone didn't get something tight, there's a lot of possibilities especially after someone just had their hands in the area. Someone needs to remove the valve cover and inspect to see what happened?
