Turn signal help
Rep Power: 0 Turn signal help
I just got this 97 Honda Civic ex first off when I bought it the right side turn signals flashed fast but still blinks so I changed every bulb twice on right side still blinks fast except for when the running lights or head lights are on it slows to below normal. I cleaned the grounds and put grounds straight to frame and battery and didn't change nothing and I doubled checked all bulbs are correct size the flasher is new I put 2 different ones in and the fuse is good any help be great it's driving me crazy
Rep Power: 0 Re: Turn signal help
Anyone?
You're probably missing something that should be easy to SEE in the lights if you really look.
Turn on 4 way flashers, stare at the front and stare at the back of the car.
Compare left to right. What's lighting up just a little different?
Leave the 4 ways on and turn on the rest of the lights.
Now look at the fronts and rears. Where's the difference?
Any side markers supposed to flash? (IDK, just guessing)
If it flashes fast on one side then that usually means the current draw is not high enough, usually meaning a bulb is out or the wattage of a bulb is not high enough.
To elaborate on post #3: Just lighting up isn't good enough, the bulbs must be the correct brightness at the correct times. If you have the front bulb wired wrong or installed wrong (or wrong bulb altogether), the dim filament could blink with the turn signals and the bright one would come on with the park lights.
If the other side works correctly, try swapping the front park/turn bulbs and sockets.
steveneddy
05-19-2015 02:39 PM
my2k1vic
01-08-2002 08:31 PM
