1999 civic automatic shifting problems
Old 04-30-2014
skramer's Avatar
skramer is an unknown quantity at this point
Hi all,
My daughters '99 civic is an automatic. I don't drive it much and just noticed that the gear selector is really sticky. I depressed the button and pulled the shifter back and it just didn't feel like any other car that I have ever driven. Once in gear, it runs great...through all the gears. Is there anything I can do to loosen this up? has anyone ever had this happen?
thank you
Scott
skramer is offline
Old 04-30-2014
Super Moderator
Poopies's Avatar
Re: 1999 civic automatic shifting problems
Have you tried changing the transmission fluid? Using Honda ATF would be pretty cheap if that's all it needs.
Poopies is offline
Old 04-30-2014
skramer's Avatar
No, I have not. the problem feels like some stickiness in the shifter. Maybe in the linkage somewhere. This car really shifts great through the gears while driving. its just getting it into the gears that seems sticky
skramer is offline
Old 04-30-2014
skramer's Avatar
Looking into it I bit further, could the guy I bought this car from just put really thick oil in the tranny to prevent slippage? I've heard that people will sometimes do this...
skramer is offline
Old 04-30-2014
Super Moderator
Poopies's Avatar
I'm not sure. Since it's shifting between gears just fine it's probably not a fluid thing. Fluid changing is just good to change every so often and it's a cheap way to eliminate one possibility in your case. I'm sure one of our resident automotive experts will be here before too long.
Poopies is offline
Old 04-30-2014
I'd guess from the description that the problem will be in the shifter or cable.
People often spill sugary drinks on the shifter...... You should know what happens a couple weeks later.
Pull the shifter assembly off the floor, strip it, dunk it in hot soapy water for a while to loosen the syrup.
Then there's the shift cable, and the linkage and pivots where it connects under the trans.
I'd probably isolate, disconnect cable under the trans and see if the problem is still present. Then disconnect the cable from the shifter, check again.
You have some investigating to do.
HTH
ezone is offline
Old 05-05-2014
Ali6500's Avatar
Ali6500 should not be trusted
You need to change its transmission.
Ali6500 is offline
Old 05-05-2014
^Why?^
ezone is offline
Old 07-30-2014
skramer's Avatar
Ali6500
no way. Change the transmission! I'm gonna try Ezones suggestion. Makes more sense to me.. Once in gear, this thing runs like a scalded dog. It just doesn't go into gear like either of my other Hondas have or any other car that I've ever owned for that matter
skramer is offline
usajags84
15
08-19-2015 03:12 AM
usajags84
05-10-2015 08:11 AM
dragonsblood
04-27-2015 12:28 PM
chgofirefighter
04-18-2015 08:08 PM
Russps
11-08-2001 02:00 AM
Quick Reply: 1999 civic automatic shifting problems
