Sandwich plate leaking and Fuel Filter leaking
Old 04-18-2014
Lord Sin
Lordsin's Avatar
Lordsin is an unknown quantity at this point
As the title says both are leaking. Fuel filter leaking from the bottom and top of the screw on bolt to the feed hose that goes into the injector rail.
Sandwhich plate leaking oil I tried to tighten the bolt all the way down to make it flush with the block and the oil filter could not be tighten or started.
Lordsin is offline
Old 04-19-2014
Re: Sandwich plate leaking and Fuel Filter leaking
Got pics?
Got new seals?
ezone is offline
Old 04-19-2014
Lord Sin
Lordsin's Avatar
No pics the leak is a small stream. Bought a new fuel filter and it was the same. I'll take some tomorrow morning
Lordsin is offline
Old 04-22-2014
Lord Sin
Lordsin's Avatar
Changed the fuel filter outlet hose that goes into the fuel rail, new banjo bolt with aluminum washers. Removed the sandwich plate and added a few washers so the plate is flush and clean against the block.
Lordsin is offline
dpru
05-26-2015 07:01 PM
Shakzhussain
05-17-2015 12:03 PM
Ninetyatecivic
05-09-2015 07:48 PM
green01civic
04-29-2015 01:36 PM
superstanko
04-28-2015 04:38 AM
Quick Reply: Sandwich plate leaking and Fuel Filter leaking
