97 civic fog lights not working
Rep Power: 0 97 civic fog lights not working
hello guys i just installed my civic ebay fog lights today perfectly, the switch even lights up orange like its supossed to, fuse is good, relay should be too, but the lights just dont light up, has anybody experienced this before? i tried searching but couldnt come up on much, thank you for your time.
Prelude Owner
Re: 97 civic fog lights not working
Ok, so your probably getting power to your relay if it is clicking (best to check with a meter). Is the fuse from the relay to the fog lights ok?
You need to check if your getting power to the lights and work back to the switch. A test light would work. A wet tongue would also.
Rep Power: 0 Re: 97 civic fog lights not working
okay so the company sent me new wiring, plugged it all up, new relay and switch, nothing, light on switch comes on, but still nothing, whats wrong?
Complete cooling system service. Drain, flush, new thermostat, clean exterior of radiator, install 50/50 mix of coolant, bleed air from system, check operation of water pump and cooling fan.
CarStuff
12-06-2020 12:52 PM
Linda0818
04-23-2015 11:30 AM
dooner24
04-14-2015 07:51 PM
