sticky manual windows
Rep Power: 0 sticky manual windows
I have a 1997 Honda DX. my Windows are difficult to roll up and down, to the point where I'm afraid of breaking my plastic window handles. What do you do to clean or lubricate the windows?is my problem with lubrication?
Re: sticky manual windows
I'd grab just about any silicone spray lubricant first.
Spray it heavily into the vertical rubber channels where the glass has to slide.
Work the window up and down as you spray to distribute the lube.
Look and think, this should be self explanatory.
Hell....
Glass run channel
From Wikipedia, the free encyclopedia
A glass run channel is a groove, normally made of http://en.wikipedia.org/wiki/Rubber or http://en.wikipedia.org/wiki/Plastic, that is found around http://en.wikipedia.org/wiki/Window (most commonly http://en.wikipedia.org/wiki/Car_windows).http://en.wikipedia.org/wiki/Glass_run_channel#cite_note-1http://en.wikipedia.org/wiki/Glass_run_channel#cite_note-2http://en.wikipedia.org/wiki/Glass_run_channel#cite_note-3 The primary purpose of a glass run channel is to provide a http://en.wikipedia.org/wiki/Seal_%28mechanical%29 for the window
This page has a pic: http://en.wikipedia.org/wiki/File:Gl...uck_window.jpg
Not if hosing it from above works.
Hell....
Glass run channel
Do I have to take off teh inner panel?
EDIT: Damn, that copy and paste didn't work too well.
Rep Power: 0 Re: sticky manual windows
Tried it, doesn't seem to make a difference. I will also say that the stickiness varies with window height. While I roll the window down, it starts off easy and then gets sticky and then gets easy again.
I have to eat crow here, and say that the silicone spray lubricant did help my windows stickiness problem. I guess I just needed to wait for the silicon to dry! Thanks ezone
Well, that confirms where the problem lies.. now, what to do about it?
You will probably need to respray whenever the window starts feeling tight again. Most people will do this and live with it, no further work involved.
Next (drastic) step would be to seriously clean the rubber channel seals, or replace them. Years of dirt accumulation is what normally makes the seals drag on the glass.
Dangerousjordan
07-27-2015 03:43 PM
breanna_17
07-21-2015 04:01 PM
estes53
07-20-2015 10:43 PM
ballmich
07-09-2015 11:59 AM
