Valve cover bolt snapped and stuck in engine block
Old 04-17-2013
x3nzox's Avatar
x3nzox is an unknown quantity at this point
My idiot *** turned the valve cover bolt the wrong way and it snapped in half
98civic ex, its the smaller bolt of the 5 bolts that hold down the valve cover
Any1 have any ideas on how to get it out??
x3nzox is offline
Old 04-17-2013
Received 1,143 Likes on 798 Posts
Re: Valve cover bolt snapped and stuck in engine block
Drill and screw extractor
xRiCeBoYx is offline
Old 04-17-2013
Put down the wrenches. Close the hood, back away from the car slowly.
Actually, about the only way is to extract it. I'd put covers (towels) and a magnet all around so metal chips can't fall into the engine, and drill it out where it sits.
Drill down the center with a left-handed drill bit. Hopefully the bit will catch and spin the broken piece right out. If not, then I'd use a fluted remover to back it out with. I'd only try an EZ Out if the bolt piece is loose enough to spin.
(EZ Out is a last resort for a stuck bolt for me, because they can spread the metal and cause it to wedge and jam in the hole.)
Or, you could pull the rockertrain off and take it apart, take just that cap in to a machine shop and have them remove the broken bolt piece.
But if you already wrenched the very first bolt the wrong direction enough to snap it off, I'd worry about you attempting to take this apart and get it reassembled without major damage to the valves.
Or.....
Put the valve cover back on, duct tape over the hole, drive to a shop to get it extracted.
HTH
ezone is offline
Old 04-18-2013
Lord Sin
Lordsin's Avatar
Lordsin is an unknown quantity at this point
Righty righty lefty loosy. How did you put so much force into the bolt in the first place? I would use a small drill bit, a tap and dye set and a vacuum to suck up the small little metal pieces while drilling. Hope you don't plan on doing major work on the head.
Lordsin is offline
Old 04-18-2013
marek91's Avatar
marek91 is an unknown quantity at this point
removing the valve cover to paint it Type Red for the added 50 HP on the D series motor!!
marek91 is offline
Old 04-28-2013
jald3rd's Avatar
jald3rd is an unknown quantity at this point
got the same problem last friday. i over tight the bolt, the bolt broke. I use a tiny drill bit to get a small hole, then hammer a star crew driver into the hole that help me took out the broken bolt. bought a bolt in autozone and use the original washer
jald3rd is offline
LionSpratt
01-29-2017 11:07 PM
Supramk3
05-11-2015 07:55 PM
JohnnyBxo
16
05-09-2015 05:53 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Valve cover bolt snapped and stuck in engine block
