Frustration w/ Door Actuator
Autocross Padawan
Rep Power: 186 Frustration w/ Door Actuator
Hey guys,
Took out my passenger side door actuator today..well, in more than one piece. I read up on gearbox's DIY and though it was (extremely) helpful, I was unable to take this part off: (I had to cut the metal to get it out and unscrew it) Now what I'm wondering.. how on earth are you supposed to get this damn piece off so I can put it on the new actuator?
Thanks.
Thanks.
Autocross Padawan
Rep Power: 186 Re: Frustration w/ Door Actuator
The entire door lock assembly. That's the piece that screws into the door handle so when you lift the door handle it lifts the latch in the assembly that opens the door.
Quick pic of it before I took it out:
Kenny the Ricer
I cant really make out what it is...
Why are you replacing the entire lock assembly?
if the motor is fried, u can just replace the actuator itself
https://www.civicforums.com/forums/1...-actuator.html
Check that link out
Check that link out
Autocross Padawan
The bottom half is the actuator on the 6th gen -- to get access to it you need to fully take it out in order to get access to the screws in order to take it out. I probably didn't have to fully take it out but my big ogre sized hands couldn't get in there to take out all the screws.
Rep Power: 787 Re: Frustration w/ Door Actuator
i just replaced that part on my 02 civic yesterday and it took 5 mins. take a few screws out, the window channel, and the rods, then it just comes out. im not sure why you are messing with the handle at all. you just need to replace that part above. altho judging by your first pic, it looks like you broke the door handle where the rod connects. that clip can be a pain to squeeze out the rod, but a pair of wide nose pliars did the job for me. you made a big mistake cutting that off and now you need a whole new door handle too. the rod shouldve been able to squeeze out of that plastic clip.
i had the opposite problem that most have. my actuator worked fine, but the locking part was messed and my key wouldnt even turn it. only power lock worked.
Autocross Padawan
No I didn't break that part of the door handle it actually just screwed out. The new actuator/door locking mechanism comes with a new one so I can screw it back in when I get the new one (that's why I thought I had to take the whole thing out in the first place). But yeah overall I realized I shouldn't have taken the whole damn thing out. Ah well, I seem to always learn stuff the hard way first.
Autocross Padawan
Not yet, I'm waiting for a new door motor to come in .. figured since I had the door panel off might as well do it before putting everything back together.
whitelight75
07-30-2014 08:47 PM
streetglower
Interior DIY
48
02-15-2012 10:06 AM
gearbox
7th Gen Do It Yourself Articles
05-02-2008 12:34 AM
