Power Window Issues
Rep Power: 0 Power Window Issues
From the master switch I can work all the windows except for the passenger side. Also when the back windows are down the indiviual switch for both will not work. I can only rolled them up from the master swicth if this makes sense. I've taken apart the master switch and cleaned it properly along with checking the fuses. What should I do?
1 Post
Rep Power: 165 Re: Power Window Issues
I would start by removing the door skins and lubing the tracks with a transparent teflon lube like liquid wrench. Once thats done move onto checking power for the switches. It sounds to me like you may have problems with the master switch sending power to the individual doors, its common for them to wear out over the years.
ClapAlongChorus
Electrical
10-28-2021 10:50 PM
got2kids
05-09-2015 06:45 PM
