Transmission won't engage....
Old 10-27-2010
sp103154's Avatar
sp103154 is an unknown quantity at this point
Here's the problem: Car starts fine, Clutch pedal feels and seem to be fine, transmission shifts to all gears with the clutch depressed as well as without the clutch but it will not engage, perpetual neutral? There are no noises, there have been no noises and seems to me that if the clutch disk was worn out the trans would not shift through all the gears?
This is a 5 speed manual, not an auto. Anyone has the solution?
sp103154 is offline
Old 11-13-2010
Scrivyscriv's Avatar
Scrivyscriv is an unknown quantity at this point
Re: Transmission won't engage....
Can you change gears with the clutch released and engine running? Any history of problems or noises prior to now?
Scrivyscriv is offline
Old 11-14-2010
lazlong's Avatar
Sounds like a broken clutch cable/ link. If you have an hydraulic clutch check for leaks at the clutch master cylinder and slave cylinder. Start at the slave cylinder, that's usually the first to break.
The slave cylinder has a metal line going to it and is on the clutch casing. I have a 7th gen but, yours should look similar:
lazlong is offline
mattdoc
03-14-2017 12:10 PM
Boostgst
06-29-2015 11:38 AM
97-DX-Lover
06-14-2015 06:07 PM
bsmiley
04-27-2015 01:27 PM
Richkid23
04-19-2015 12:53 PM
Quick Reply: Transmission won't engage....
