7th Generation Civic In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
02 civic immobilizer removal?
Old 11-25-2018
Shavalavo is an unknown quantity at this point
I'm having problems with my immobilizer and it's not in my budget to take it into the dealer right now. Is there a way to remove/disable the immobilizer so that I can drive it? the car is mechanically sound other than the immobilizer issue. I don't care about security, she has alot of miles and I just need something to get me to work til I can get a new car.
any help is greatly appreciated!
Shavalavo is offline
Old 11-25-2018
Slumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of light
Re: 02 civic immobilizer removal?
Just to note, this will also disable the computer from being able to shutdown the fuel pump in a crash which may result in killing everyone so use at your own risk.
The immobilizer controls power to the fuel pump relay behind the glove box.
Remove the fuel pump relay and jumper the appropriate 2 connectors in that socket.
Your green light will flash, but otherwise your driving.
Slumpertcivic is offline
Old 11-25-2018
ah, thanks! doesnt the immobilizer disable spark as well?
Old 11-25-2018
Nope
Colin42 is offline
Old 11-26-2018
NDNV's Avatar
NDNV is on a distinguished road
In case it is a problem with the key, try the other keys?
NDNV is offline
Old 01-18-2019
Bdparis03civic is an unknown quantity at this point
I'm having same issue but mine has enabled the plugs and injectors also I need it fixed on budget someone broke in and cut all the wires so I had to wire up push button and toggle switch but still nothing they cut all the wires to the immobilizer and security trying to steal the car I need help someone please
Bdparis03civic is offline
Old 01-18-2019
What your describing is a horrific event that has happened to your car.
You could easily spend hundreds (thousands) of dollars to a shop to try to find and repair all the damages, and still end up with a car that wonít run.
If this was my car,
I would find a similar model at a pick a part junkyard.
Verify it has a unmolested dash and wire harness.
Discuss with the junkyard manager what you intend to do and agree upon a price they will sell you the harnesses for in writing. (More than once I have had them backtrack and say ohhh you didnít say that part, itís twice as much)
Pull the existing dash and wire harness out of the current car paying special note to every tool I need to accomplish the job, and what unexpected things I broke trying to get it out.
Pack a lunch and head to the junkyard with the same set of tools.
Remove the dash and all the harnesses and extra bits broken at home.
Arrive back home, install harnesses and try to start car before putting dash back together.
Old 01-18-2019
I've read that you can decide saulder it from ecu but I need to know location of chip I could try it first if that doesn't work I don't have the money to replace right now but I will be forced to sell but really trying to avoid sense it's my dd
Old 01-18-2019
Whomever vandalized the car was certainly an amateur or a kid, not a professional thief IMO.
Got insurance?
I'd be fixing the wiring or replacing wiring as necessary
ezone is offline
Old 01-18-2019
Just liability does cover that yeah I got most of it just don't know what all I need hooked up
chriswaskin
01-09-2011 10:49 PM
pdgarner
08-10-2010 08:03 PM
Frewsky
04-03-2009 01:41 PM
2k1_Toaster
04-11-2006 05:11 AM
mattuf64
03-20-2006 10:31 AM
Quick Reply: 02 civic immobilizer removal?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
