Possible head gasket failure after 8 months? - Honda Civic Forum
7th Generation Civic In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
Old 11-09-2018
wwhitby is an unknown quantity at this point
All,
Back in March, I had the head gasket replaced in my LX at 193,000 miles. It never overheated, but it did get about 3/4 of the way up the gauge. I also had a oil leak and coolant was leaking into the #1 cylinder. The shop replaced the timing belt and water pump (it was time for that as well) and sent the head to a machine shop to have it checked out.
Everything has been fine until last week when I would smell coolant after I got home or got to work. The check engine light has come on twice, and both times it was throwing a P0128 (Coolant Temperature Below Thermostat Regulating Temperature.) I also noticed that it had used a little coolant. The coolant level in the radiator would be down to a little under the neck (the fins were covered but I could see them) and some used out of the recovery tank. So far, my Civic has not overheated. In fact, the temp gauge has not moved above the line it usually sits at. No coolant "smoke" from under the hood either.
I've looked for leaks and can't find any. There's no puddles on anything of the components or under the car. Just the smell of coolant.
This morning, I added a tiny amount of coolant to top it up and decided to test it by cranking up my Civic while the radiator cap was off. When I cranked it up, I could see coolant shooting out about 1-2 inches from the top in a mini Old Faithful. I have not seen any white smoke, but I didn't see any last time when the head gasket was bad.
What do y'all think? Maybe i'm a little paranoid since I don't have the money to pay for another head gasket......
wwhitby is offline
Old 11-09-2018
Colin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of light
Re: Possible head gasket failure after 8 months?
did you use a honda head gasket? or an aftermarket one?
Colin42 is offline
Old 11-09-2018
A local shop did the work, so I don't know what they used. If I had to guess, probably an aftermarket one.
wwhitby is offline
Old 11-09-2018
That's probably the issue, need to do more tests to be sure though.
Do you see evidence of any leaks in the engine bay?
read this thread:
https://www.civicforums.com/forums/3...reference.html
there's a video in it showing how to test if the headgasket is bad
Colin42 is offline
Old 11-09-2018
I don't see any coolant leaks, but I can smell coolant.
A few more things:
  • the shop did replace my radiator cap, but its an aftermarket Motorad radiator cap. I haven't had any problems with it, but should I try replacing the cap first?
  • Should I also replace the thermostat? I have an OEM Honda one in the box.
Also, I do get heat out of my heater.
wwhitby is offline
Old 11-09-2018
pleasure spiked with pain
GolNat's Avatar
I’m wondering if they put in a new thermostat but it was the wrong temp range. No warranty on the work?
*Or they didn’t replace it and it’s bad now. Seems odd if they did put the wrong range in it would take 8 months to cause an issue.
GolNat is offline
Old 11-09-2018
Originally Posted by GolNat View Post
Iím wondering if they put in a new thermostat but it was the wrong temp range. No warranty on the work?
They do have a warranty, but i'm not sure how long it is for. I'll look for my paperwork and see.
I did order a new radiator cap just to be on the safe side. I'm also going to replace the thermostat with the OEM one I had bought but didn't put in before the head gasket was replaced. If nothing else, it will rule a couple of things out.
It didn't seem like any of this started until we had our first cold snap and I was running the heater instead of the A/C......
wwhitby is offline
Old 11-09-2018
GolNat's Avatar
I wonder if they forgot to turn on the heater when they burped it? Turning it on may have introduced air!?!
GolNat is offline
Old 11-09-2018
Its certainly possible. I was also planning on burping the radiator this weekend just to see what happens.
wwhitby is offline
Old 11-09-2018
use test below to know if the gasket is the cause.
if it pass this test, go to other suspects.
sdaidoji is offline
Old 11-09-2018
FWIW, I'll go ahead and replace the thermostat before burping it. I've read that non-OEM thermostats can cause problems. This one could have gone bad for all I know. At least it will be another thing checked off the list.
I did check the coolant level in the radiator before I went to lunch. The coolant level hadn't changed.
wwhitby is offline
Old 11-12-2018
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
I had the same code for my civic. It would take long to come up to temp when it was cold outside. When I removed it the thermostat had the little seal broken allowing coolant to flow even when it was closed. After replacing i got better gas mileage and quick heat from the heater.
Also the no burp theory sounds plausible, and now that you used the heater you got a small bubble to come out making the level go down a tad.
GusBuz is offline
Old 11-17-2018
siliconvalley is an unknown quantity at this point
My mechanic let me buy Honda dealer parts and gave to him for head gasket, water pump, timing belt job :-)
siliconvalley is offline
honkeydonkey
11-09-2018 04:27 PM
Xavier Corral
12-06-2015 07:10 PM
mel1803
02-28-2015 01:42 PM
Howzer05
01-04-2012 08:47 AM
redright9
01-05-2011 03:23 PM
Quick Reply: Possible head gasket failure after 8 months?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
