Another blown head gasket?
Rep Power: 0 Another blown head gasket?
So back in August I replaced my head gasket due to overheating. The big giveaway was the overflow was filling up and spilling everywhere. So I replaced the head gasket and yesterday on my way home from work the ac turned hot and I looked at the temperature gauge and it was 3/4 the way up. I stopped and sure enough the overflow was spilling coolant out. I just replaced this head gasket 6k miles ago so why would it fail again? I torqued everything down in the correct sequences and to the correct amount. However I did NOT get the head machined but I checked my surface with my feeler gauges and everything was under .001 which lead to me believing the head was not warped. If it is the head gasket I will get the head machined no matter what this time. So my ultimate question is what do ya'll thing caused this again? I'm kind of leaning towards a warped head that I possibly didnt catch?
Received 1,126 Likes
Rep Power: 190 Re: Another blown head gasket?
Did you use an OEM Honda gasket?
Did you fix what ever caused the engine to overheat in the first place? Bad fans, temp sensor, thermostat, etc
Rep Power: 0 Re: Another blown head gasket?
Well that's problem one. Did you clean the head and block mating surfaces? How did you clean them? Were they the correct smoothness?
The fans are kicking on, thermostat has been replaced, water pump was replaced 15k miles ago with new belt. I bought the car in June so I'm not totally sure what happened if it overheated on the previous owner or not.
car only has 121k miles on it now.
I went ahead a pulled the head today and will be dropping it off at the machine shop Monday morning. I will call Honda Monday morning and pick up a OEM gasket set. I wanted to pull the head and get in machined just to rule out the possibility of a warped head.
They only drove the car maybe 2 miles whenever they drove it. It was an elderly lady who owned the car and then she passed on so her son who already owned vehicles would rarely drive it. Seemed like a decent guy I purchased it from him at his business location so I doubt he knew it had any issues.
There have been some posters here reporting alarmingly premature failures of aftermarket head gaskets.
Did you actually prove a head gasket breach before pulling the head a second time?
If the head actually measured flat I would not want it to be machined.
Is the radiator cap good?
Is the radiator neck burned from a severe overheat event (steam erosion), now it can't hold pressure because the cap doesn't seal correctly, so liquid ends up overfilling the reservoir?
Did you measure it?
Warped? Close to zero IMO. I've seen many severe overheats over the years and not once witnessed a block casting problem resulting from it. Collapsed piston rings yes, warped head yes, but not warped block.
However, I've seen a lot of damage caused by improper gasket removal procedures.
Did you measure it?
Phred
05-01-2011 01:17 AM
claythorpe
07-12-2010 11:58 PM
