02 Coupe drivers and rear speakers not working.
Rep Power: 170 02 Coupe drivers and rear speakers not working.
I believe its a short. The speakers work sometimes but usually not. I took the door panel off and theres a nick on the speaker wire but it still looks fine. Where and what do I check ??
Super Moderator
Received 1,848 Likes
Rep Power: 196 Re: 02 Coupe drivers and rear speakers not working.
Is the whole system still stock or has something been replaced?
Prelude Owner
Check continuity from the speaker(+)&(-) back to the headunit. Also check from speaker (+)&(-) to ground for a short. While doing this test move wires and jiggle things around to simulate driving see you can get an open circuit or short to ground.
Super Moderator
How was the head unit install done? Was an adapter used to avoid cutting the stock harness? Were wires just twisted together, were they soldered, or were crimping connectors used?
Received 1,126 Likes
Rep Power: 190 Re: 02 Coupe drivers and rear speakers not working.
How well are they crimped?
I know I had to redo some when I did my truck 9 years ago. That was my first install
Jessnbryan12
04-05-2018 07:41 PM
ricerflyby
03-26-2013 10:28 AM
Nameless
12-24-2007 12:51 AM
