Knocking in front when turning strut/spring
Rep Power: 0 Knocking in front when turning strut/spring
ok so I’ve done some looking on this site a lot and on other various diy sites, when I’m turning to the left exclusively is when I hear this loud thud or knock from my driver side strut. From what I’ve been retaining from my searches is it possible that it’s just my coil or spring and not the entire strut? I also know there’s a very specific way to line up your new coils on these Honda’s too. Also is it possible it’s just the driver side that needs replacing i understand that swapping out both would be the smartest route , however when I have my car on stands and shake the two front tires side to side the driver side is predominantly where I hear this; when i jump over to passenger side and do the same I do hear the noise but I’m wondering if it’s not from where the problem area originated because on my pass side it’s not as loud. Please send help ASAP thanks
Rep Power: 78 Re: Knocking in front when turning strut/spring
normally what happens is the bearing(which makes the strut rotate as the wheel turns left and right) on the top of the strut fails, initially you hear clicking and clanging, then one day when you turn the wheel, the springs crack off and the noise it makes gets scarier. i would replace the entire assemblies on both sides.
i dealt with that recently on a malibu. these are what came out:
notice how both springs are cracked in half
also had about 50 little bb's roll around the floor from the bearing cup on top.
Super Moderator
Received 1,848 Likes
Rep Power: 196 Re: Knocking in front when turning strut/spring
Attachment 112148
Attachment 112148
Rep Power: 0 Re: Knocking in front when turning strut/spring
Attachment 112148
Attachment 112148
CivicTwinZ
29
03-24-2012 11:47 PM
fripperiffic
12-03-2010 10:23 PM
cwo715
08-15-2006 12:19 AM
integ108
08-06-2003 06:08 PM
Coastie
07-26-2003 08:17 PM
