Bogging out when accelerating
Rep Power: 0 Bogging out when accelerating
My car has just gotten a swap done. Nothing major just another d17. Well the issue is that now i cant drive my car at all. it was fine for about 3 days and then it decided to start choking on me. at first i was told maybe its not getting fuel thru so i changed my fuel injectors. now i can rev a little but still not driveable. What can it be???
Rep Power: 0 Re: Bogging out when accelerating
Could be anything from bad gas to fuel pump. But if it’s a recent new engine a lot of it could be valve timing causing it to bog out, the camshaft probably isn’t able to control the intake and exhaust valves at the right time causing your engine to shut down or bog out. I would just start with timing belt and adjust it to see if that helps the issue. It all sounds like just the new engine not being able to communicate and function properly. Hope that helps
Yea first check would be scan tool, then timing marks check.
If a bolt came lose and fell into the belt or the tensioner failed your could have skipped a tooth or two.
Hard to diagnose without actually checking marks.
it’s hard to tell what the cause of it would be. I guessed the timing since it’s a new engine or could just be the main computer not being able to adjust to the engine
Courtkoble
04-13-2017 12:29 AM
westvilleguy
10-05-2014 06:23 PM
ValleyCivic
04-21-2012 07:00 PM
Buddy1172
01-09-2012 05:22 AM
b4nkshot
12-19-2009 09:23 PM
