5th Gear Popping Out
Rep Power: 0 5th Gear Popping Out
I just put a new exedy stage 1 clutch in my d17a2, and about 50 miles in, 5th gear pops out while cruising. I'm thinking the guy that put my clutch in didn't do my linkage correctly, but I'm reading that it could be a synchro sleeve or shift fork. Has anyone had this problem, due to shift linkage being put back incorrectly after a clutch replacement, or is this an internal problem that just now came up most likely?
Received 1,122 Likes
Rep Power: 190 Re: 5th Gear Popping Out
could be fluid level is low
Return to your clutch installer? Let them fix their issues?
Pay attention the the parts about filling, not draining.
Rep Power: 0 Re: 5th Gear Popping Out
https://www.youtube.com/watch?v=-Hl4utURDEU
Possible your installer never even took the shift linkage off when he changed the clutch.
Check your pivot ball at base of the shifter, when those crack they can lead to poor engagement.
he said that he put everything back together correctly, but he’s going to take it back and fix it. I guess we’ll see in a couple of days.
mountainkat47
Transmission
4 Weeks Ago 08:07 AM
Jdm1011
09-08-2017 10:00 PM
Miami240
04-19-2004 12:03 PM
