Where’ abouts on gasket &oring locations
Rep Power: 0 Where’ abouts on gasket &oring locations
Alright so ha let’s try this again the first FOUR are the ones I’m unsure about like I said I think the small ones may go to fuel injectors but idk I’ll also send one of the injectors so it’s fresh but I’ll send that last
https://imgur.com/gallery/K7XrW
https://imgur.com/gallery/2HLeM
https://imgur.com/gallery/GGre0
https://imgur.com/gallery/aRyg7
so then next I have what ones I know where they go I’m sure so going from left to the top to the right it would be egr, water pump, and that last one i believe goes alongside the cam actually it’s not but it’s thst housing that the shorter steel hose runs from the water pump lol I just walked over to it and it matches
https://imgur.com/gallery/9gbeI
then last I think all those small ones labeled bolts are in the head do mechanic shoulda replaced em along with that cam gasket too right?
https://imgur.com/gallery/VgniD
https://imgur.com/gallery/vhrF7 and that injector as promised
Re: Where’ abouts on gasket &oring locations
The bigger one thats a circle with a box on top is the throttle body gasket
the 4 ones about size of a 50c piece are the spark plug tube seals.
do not use any of those for your fuel injectors, it’s orange for a very good reason, different type of rubber that can hold up.
By the count I think they expect you to replace the valve cover bolt plugs with those short fat orings.
Might not not be a bad idea, the oem ones pretty much need to be cut off and replacements boiled for a minute to get on.
The big one that looks like a plug is possibly meant to replace the camshaft end plug on passenger side.
the one that’s rectangle with a box is for the water housing.
Rep Power: 0 Re: Where’ abouts on gasket &oring locations
Thanks for the input to all you fine people however I have set aside 4 rings that i am almost certain that are meant to be for each coil or spark plug but is there any that are meant for each coil perhaps?
t2los
08-24-2012 07:30 PM
mal68ibu
06-24-2011 12:21 AM
MangoEX
16
06-18-2007 03:09 AM
