7th Generation Civic In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
Civic ex Burning/ leaking a lot of oil
Old 02-15-2018
Puccillo is an unknown quantity at this point
Exclamation Civic ex Burning/ leaking a lot of oil
I have a 2003 EX I had just swapped with a JDM engine because my old one had gotten “crank walk” from a very excessively big stage 3 clutch previous owner put in. I had it swapped with a JDM engine with less than 60k or so that is what the importer I bought it from in NYC said. I put new plugs, thermostat in it and when I got it back from
the mechanic I noticed 2 days later coming to a stop before work my oil light came on. Checked it after work and it was pretty much really low on oil like empty almost so I added a quart and drove home about 20 miles. Next morning after I woke up there was oil on my garage floor. And then noticed my oil light come on again after work, checked it and low again and it does smoke really bad.. what could this be from?
Puccillo is offline
Old 02-15-2018
mikey1's Avatar
Re: Civic ex Burning/ leaking a lot of oil
you are basically asking a blind man if he can see the trees,
i can't see anything from here
crawl under and look??
mikey1 is offline
Old 02-15-2018
Slumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of light
Since the exhaust literally runs right under the engine, almost every oil leak can result in smelling burning oil.
top to bottom,
Spark plug tube seals
Oil cap gasket
Valve cover bolt seals
dipstick o ring
cam shaft seal
cam shaft plug
Valve cover gasket
Rocker arm sealant
head gasket
oil Pressure switch
pcv Valve or plate
block
Oil filter
oil pump oring
rear oil seal
crank oil seal
oil pump sealant
rear sealant
oil pan gasket
oil pan
drain bolt
if I forgot someplace you can be leaking oil, please forgive me.
Anything else besides your drain plug and oil filter being loose and I would take it back to the JDM shop you got it from.
Slumpertcivic is offline
Old 02-16-2018
310civicEX is an unknown quantity at this point
cam end cap see if theres tons of oil around your EGR ..if so your end cap is bad
310civicEX is offline
Dan1232620
07-03-2013 08:10 PM
satown210
03-02-2011 05:46 AM
Emiras
1st - 5th Generation Civic
07-17-2009 08:12 PM
dru106
South Cali
38
01-14-2007 03:13 PM
AlpineCivic
08-24-2005 07:13 PM
Quick Reply: Civic ex Burning/ leaking a lot of oil
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
