Hunting Down Coolant Leak
I have a 2005 Civic VP that I'm certain is losing coolant. The problem isn't bad when I'm driving around town but for work twice a week I drive from sea level, over 6600 feet, and back down...and then do it again to return home. This is especially when I notice my heat increase if I don't add coolant before the trip.
Will a pressure check of the coolant system give me any clue whether my civic is leaking from the head gasket?
Another problem with the coolant loss I've noticed is that when I turn the heater on the problem becomes worse. I've noticed that after running with the heater on the fluid loss is more significant. The thing is I don't have any coolant leaking on the passenger side.
It seems to me as if each time I turn on the heater, which is possibly empty from leaking, a chunk of the coolant in the system is directed to the heater thus causing the amount of fluid in the system to be lowered and consequently causing the engine temperature to rise.
Any thoughts?
Any thoughts?
Re: Hunting Down Coolant Leak
Read everything in the first two posts of this thread, including watching the videos
https://www.civicforums.com/forums/3...reference.html
Any loss of coolant in the radiator combined with gain of coolant in the reservoir? Check each morning for the next few days. If you have troible visually reading the resevoir then use a bendable stick inside the reservoir.
If your car's coolant system doesn't have an exterior leak then a pressure test may possibly discover an internal leak by allowing pressure tester to hold pressure for several hours and then removing the spark plugs to check for coolant on them. An internal leak may cause a cylinder(s) to fill with coolant via a breach in the headgasket. Do not pressure test above the recommended coolant system psi rating on radiator cap or within the service manual.
A much better and quicker test is to blow 150 psi of compressed air into each spark plug hole one at a time while each cylinder is at TDC. Any leaks (head gasket breach) will show up as bubbles in the radiator neck.
Can also try a Block Test but that only confirms a leak if exhaust emmissions are getting into the coolant. A block test will not find all types of head gasket breaches.
WaryDriver
12-20-2016 12:42 PM
2002ExCivic
16
11-29-2016 08:29 AM
eswar_ner
10-08-2014 06:12 PM
bryanclauson
03-19-2013 09:53 AM
bryanclauson
03-13-2013 09:54 AM
