2001 4dr EX passenger window stuck, went down but can't pull Up - Honda Civic Forum
7th Generation Civic In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
LinkBack Thread Tools Search this Thread
Old 12-29-2017   #1
dlawrence206 is an unknown quantity at this point
Checked the fuse under the steering wheel, all good. Window is getting power best I can tell.
took off the inner door panel and the water shield. window is in the track on both sides. there are no visible obstructions.
but it still won't roll up and even with all my strength I cannot pull
the window up enough to the point I would be able to disconnect the glass from
the regulator by going through the two holes higher on the door. its
just totally stuck in the bottom of the door. Im assuming I need to take apart a component of the motor or something but i am just not sure how to proceed here. (I'll try and post pics tomorrow)
any tips on how to troubleshoot to determine the problem, how to fix it, and mostly what to dismantle
to allow the glass to slide up the regulator enough to remove it would be great.
THANK YOU FOR YOUR TIME AND PLEASE HELP!
dlawrence206 is offline   Reply With Quote
Old 12-29-2017   #2
Slumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of lightSlumpertcivic is a glorious beacon of light
Re: 2001 4dr EX passenger window stuck, went down but can't pull Up
Common issue is the bend in the wires at the body/door connection.
Pulling the connector apart right there will give you option to test for power and maybe it’s just broken enough you might get it work while you jiggle the wires
Slumpertcivic is online now   Reply With Quote
Old 12-29-2017   #3
Colin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of lightColin42 is a glorious beacon of light
this video is for a 96-00 but it's very similar to 01-05, if you skip to 2:40 they show how to move the window when it's stuck down.
Colin42 is online now   Reply With Quote
Old 01-02-2018   #4
NDNV's Avatar
NDNV is on a distinguished road
Quote:
Pulling the connector apart right there will give you option to test for power and maybe itís just broken enough you might get it work while you jiggle the wires
This is the solution to my problem when the right passenger window got stuck open. It was a broken wire at the rubber conduit area at the driver's front door. Flexing over time broke it.
NDNV is offline   Reply With Quote
Thread Thread Starter Honda Civic Forum Replies Last Post
Passenger side power window stuck in up position numbersguy Electrical 1 05-14-2015 09:51 PM
Help! Rear Window Stuck Down!!! nunzio42 I.C.E. & Electrical 2 04-18-2011 07:58 PM
01-03 4DR Rear Lip / 01-05 4DR Window Visors jonnntran Parts for Sale 4 02-11-2011 12:43 PM
Passenger window goes up but not down stevelaw18 7th Generation Civic 4 01-03-2011 02:41 PM
Civic 96 4dr passenger window stays down? vlessing I.C.E. & Electrical 5 12-22-2010 07:42 PM
Tags
2001, stuck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright © 2017 CivicForums.com
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
