'05 Honda Civic: brakes ground and failed in icy
Rep Power: 0 '05 Honda Civic: brakes ground and failed in icy
'05 Honda Civic: brakes ground and failed in icy conditions
In light snow and low speeds, the front brakes on my 2005 Honda Civic EX (manual transmission) ground and failed. I steered into the oncoming lane to avoid hitting the car in front of me (fortunately no oncoming traffic). Checking, I see slush built up all around the front tire though it's dark now and hard to tell where it built up.
Have there been any problems with the ABS on this model?
Re: '05 Honda Civic: brakes ground and failed in icy
Sounds like you were probably going too fast for the conditions (slick/snow/ice), had no traction (maybe along with poor tread condition???), and the ABS system did exactly what is designed to do.
Received 1,126 Likes
Rep Power: 190 Re: '05 Honda Civic: brakes ground and failed in icy
Do you have proper snow tires?
When you say the brakes failed, did the pedal go all the way to the floor like a line popped?
Rep Power: 0 Re: '05 Honda Civic: brakes ground and failed in icy
Since I now know that's what ABS feels like (bizarre, by the way) then the issue is simpler -- a skid. Which is explained by looking at the slushy-ice build up around my tires.
I grew up in Michigan, where snow tires are the norm, but this is Maryland. So I think four new all-season tires are in order. My mechanic mentioned that I should get new tires in a few months, but I'd say now would be the time.
The ABS did do what it was supposed to do, now that I know what ABS feels like. You're correct, the lack of braking was due to a skid. I'd gone from one visibly wet road that was well-salted to another visibly wet road ... where the salt truck sprayed me several minutes after the near-incident. The drastic change in conditions was not apparent because we were early into the snow fall.
If you can afford get winter rubber for winter and a summer tire for summer
I am very fond of the Hercules Avalanche X-Treme
They have a nice open tread for snow and slush
If you pull all the resonator box and tubes out, I am sure you could put a 50 pound bag of salt /sand on top of the transmission for better traction.
Maybe even two..
Maybe even two..
NikiCivic12
03-04-2012 07:17 PM
