Flywheel snapped??? Clutch not engaging and car won't start at the same time.
Rep Power: 0 Flywheel snapped??? Clutch not engaging and car won't start at the same time.
Hello.
I just got a used 2004 civic non vtec 5 speed manual. My brother was driving it and it looks like he burned out the clutch. From what I know there were no loud noises or breaking sounds. But there was some kind of a squeak before this, when changing gears 1-3rd gear. I thought it was the throw out bearing. The clutch was about 70-80 percent gone when i got itso I figured it would go out eventually on him as a new driver. And there was the burning clutch smell and I can push the car easily in any gear. Sounds like a simple clutch job right?
this is all fine. But at the same exact time as the clutch went out, the car is also not starting. The starter sounds like it's turning, but the belts in the engine aren't moving a mm. The engine won't turn even slightly.
I immediately took off the timing belt cover and checked that the belt hasn't snapped. It looks good and like it has been changed recently.
I'm puzzled here. The only thing I can think of is the previous owner got a ridiculously cheap lightweight flywheel and it literally snapped.
I'm about to take the car to a shop for a clutch and flywheel replacement. But im worried the engine may be locked or dead. The car has 167000k miles on it .
what do you think this is? How can I make sure the engine is alright?
other thing I can think of is what happened in my Honda xr650l and the aftermarket sprocket ate through the teeth on the output shaft, because the shaft metal was softer. This cant happen to a car right?
Re: Flywheel snapped??? Clutch not engaging and car won't start at the same time.
Clutch disc probably exploded into a huge ball of cat fur.......which may now be obstructing the starter gear (bendix) movement.
Pull the starter out and take a look, or pull the inspection plate off the bellhousing bottom and see if there's wads or material hanging there
If you seriously think the engine may be locked, put a 19mm socket on the crank pulley bolt and try to turn it counterclockwise.
Rep Power: 0 Re: Flywheel snapped??? Clutch not engaging and car won't start at the same time.
I hope you're right and that's not a joke lol.
How can I get to the crankshaft? Its literally wedged up against the wheel well.
pulling out the starter sound alike a good idea, maybe I can turn the flywheel bit by bit with a screwdriver. But lm guessing the starter is wedged deep into the engine bay
Has this ever happened to anybody?
Received 1,122 Likes
Rep Power: 190 Re: Flywheel snapped??? Clutch not engaging and car won't start at the same time.
there's a little access hole for the crank bolt in the fender liner. either crank the wheels all the way to the left or pull the driver's front wheel off.
starter is on top of the trans, pretty easy to get to. pull off the air intake tube to get better access.
Thanks, I'll give this a try. Should it be easy to turn? Also, I'm stupid for asking this, but should I be turning it clockwise or counterclockwise. Looking from the driver's side
counter clockwise as ezone mentioned.
pull the spark plugs to make it easier to turn
(this pic was not taken with the intent of showing the crank pulley but it's all there)
I assume the the spring jammed between the disc and the flywheel to crankshaft bolts
Also possible the clutch release bearing is stuck on the shaft or what remains of the release bearing
Suraj Khellawan
08-29-2017 08:50 PM
Mkalby
11-30-2012 03:31 PM
bakertime
21
03-01-2012 11:43 PM
pvd95
05-14-2009 10:04 AM
BmoreEX
07-12-2007 10:18 AM
