Check engine Cylinder 2 misfire detected
Rep Power: 0 Check engine Cylinder 2 misfire detected
hey so out of no where my car starts shaking and the check engine light came on, I check it and it gave me the code that means cylinder 2 misfire detected so I was wondering exactly what can I do.
Rep Power: 0 Re: Check engine Cylinder 2 misfire detected
Off the top of my head:
1. Check spark plugs
2. Check ignition wire
3. If the above seem okay then you need to check your fuel injectors.
Hopefully it's just a faulty spark plug or wire.
Hey man thanks for the reply and I just checked the obd2 and now it's telling me it's the 2nd,3rd, 4th and random misfire, I had changed the spark plugs when the light first came on. How do I check the wires ?
Try resetting the ECU and see if codes return. Post codes here if present.
