Persistent P0135 CEL
Rep Power: 0 Persistent P0135 CEL
Long story short - CEL P0135 never goes away. New OEM O2 upstream sensor (Denso) never fixed the problem. Sensor -heater fuse is good, but P0135 still comes up, it takes about 30 seconds to light up after reset.
Any ideas?
Thank you.
Any ideas?
Thank you.
Re: Persistent P0135 CEL
Have you followed the troubleshooting procedures in the service manual for whatever year car you have?? (05 DX, Canada?)
Does the heater have power?
Does the heater have ground?
What part number sensor did you get?
Did you ever ohm check your original sensor to make sure it was bad before replacing it?
Old sensor heater circuit ohm test is ____?
New sensor heater circuit ohm test is ____?
Rep Power: 0 Re: Persistent P0135 CEL
Yes behind glove box, there are several relays to choose from.....Check colors of all 4 wires to make sure you have the correct relay
Time for a new car I guess.
Sad, because I love my civic.
A voltmeter (and some thinking) would go a long ways toward actually figuring out what the real problem is.
Thank you.
