2005 Acura EL Upstream O2 Sensor
Rep Power: 103 2005 Acura EL Upstream O2 Sensor
My just came on in my 2005 EL and it threw the code P0134 - 02 Sensor Circuit No Activity Detected (Bank I Sensor 1).
I've been reading that the expensive Honda OE sensors are manufactured by Denso but am having a hard time finding the right one. The Denso website shows nothing for 2005 Acura EL when I search so I looked at sensors for 2005 Civic EX and still not finding the correct one.
Can one of you Honda nerds (*cough* ezone) please point me in the right direction?
Rep Power: 103 Re: 2005 Acura EL Upstream O2 Sensor
After some more research I found the Bank I sensor is actually an air fuel ratio sensor.
Went for a drive today and the CEL isn't on anymore and I didn't clear codes with scanner.
Look up the Honda/Acura part number for the AF sensor
then google the denso part number cross reference guide (It's huge, use CTRL + F to search the document)
OK I found the right sensor (Denso 234-9017). $187 Canadian dollarydoos
Is it common for these sensors to die over time and cause issues down stream with the secondary O2 sensor or catalytic converter?
Is it a good idea to replace it ASAP given that my disappeared on it's own the next day or just wait and see if the same thing happens in the future?
Sure
IMO no
IMO not usually, but possible depending on the failure: If a failure caused some extreme rich or lean condition, maybe.
Also note, catalyst monitoring by the PCM is suspended while AF and O2 fault codes are present. The cat could go bad or be ruined for any reason, but the PCM can't see/test it until all sensors are working again.
Sup to you. I'm gonna guess the code will return soon, intermittently working is still a failure.
This was my situation also. The engine light would go on and then off randomly. Sometimes for a whole day but it was always back on without delay.
After replacing the sensor it was all good. Just make sure you get the correct one for your car. I got this one from amazon https://www.amazon.com/Denso-234-901.../dp/B00122EENE
It is the same part number I used, and was exactly the same as the one that came off the car.
That's the exact one I'm looking at: https://www.amazon.ca/Denso-234-9017.../dp/B00122EENE
My hasn't returned yet. I went to Honda to get a price on JUST the sensor - over $500 after taxes
I think I'll take my chances with the one from amazon LOL.
Alright I got the new sensor installed and no CEL yet.
I noticed after the car had sat a day or two it's starting a little rough needing another crank or two from the starter. Related to new sensor possibly?
Received 1,122 Likes
Rep Power: 190 Re: 2005 Acura EL Upstream O2 Sensor
Doubt it, probably just from sitting. Check your connections, make sure they're tight and corrosion free. How old is the battery? Alternator good?
It's been cold the past few mornings in my area, maybe the car just isn't happy
RIPSAW
01-15-2017 05:37 PM
orbanp
22
10-28-2016 01:23 AM
RIPSAW
08-27-2016 10:30 PM
chi_tea
28
08-26-2016 06:00 PM
