P2646 after head gasket
Rep Power: 0 P2646 after head gasket
So I just bought an 04 em2. It has 130k on it. When I bought it 2 weeks ago I found out it needed a head gasket. Just got that done yesterday and picked the car up today. Ran great then when I hit vtec a couple times a check engine light came on for p2646. Shop can't figure out anything with it. Looked into it and found most likely cause to be fault pressure switch. I have one coming. I did the test of checking for continuity at 3000rpm with the sensor unhooked and found continuity at 3000. From what I read that means faulty pressure switch. Is there any other way to narrow this down? We just did an oil change on the car because of the bad head gasket. Oil level is fine. Vtec engages fine for a couple tries then does this. I should also state that on the shops scan tool with the car running it says the switch is on. If you drive the car the switch stays on and when vtec engages the solenoid opens. If I read correctly the switch isn't suppose to stay on all the time correct?
Rep Power: 0 Re: P2646 after head gasket
Try pulling the solenoid off and cleaning it out, could be gummed up jamming the spring inside or the filter screen could be really clogged.
Read about that, told tech after he put valve cover back on. And they were getting ready to close so gonna make sure they check that tomorrow.
Thanks!
CD
Remove your valve cover and check yours out, or show your mechanic this thread and pictures and have them recheck their work
speediq99
03-21-2020 06:35 PM
mister2
10-05-2015 09:12 PM
rechinca
08-21-2012 05:23 PM
jnlzr
04-17-2012 06:01 PM
