2001 honda civic LX exhaust manifold - Honda Civic Forum
7th Generation Civic In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
LinkBack Thread Tools Search this Thread
Old 09-09-2015   #1
jdh022764 is an unknown quantity at this point
Hello everyone, I am new to this site and I was hoping I could get some answers for some questions about replacing the factory exhaust manifold. I have a 2001 civic LX. Does anyone out there make a good replacement header with both O2 sensor holes that will match up to the OEM exhaust? I see the headers out there with the two holes for the O2 sensors that looks like it would work. Can anyone tell me why they put the top O2 sensor hole on the right side of the header ? will the factory sensor wire be long enough ? Next question, how will the O2 sensors behave without a convertor anymore. One last question, has anyone gutted out the convertor and reinstalled it? If anyone knows of headers that are nice please let me know, the only ones I have checked out are the ones on ebay with different coatings on the tubes and I am not sure what is the best coatings to get. thank you everyone.
jdh022764 is offline   Reply With Quote
Old 09-10-2015   #2
Administrative Rice. WAT?!
xRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud ofxRiCeBoYx has much to be proud of
Re: 2001 honda civic LX exhaust manifold
Without a proper/properly working cat, your car will throw a p0420 code.
xRiCeBoYx is offline   Reply With Quote
Old 09-10-2015   #3
emich is an unknown quantity at this point
Agree without a cat you have to modify the O2 sensor to avoid CEL
emich is offline   Reply With Quote
Old 09-10-2015   #4
Quote:
is modifying the 02 sensor possible to do and do both of the them or just the top or bottom 02 , thank you
Old 09-10-2015   #5
Quote:
I was talking about secondary O2 sensor only. You can't modify the primary. There was a diagram few months ago in the forum regarding fixing P0420 (bad cat) code.
Old 10-06-2015   #6
EM2ti
maxtierney's Avatar
A little late to the game, sorry.
Just use an mechanical "extension" (sometimes called a CEL eliminator, O2 Spacer, etc.), on your secondary sensor. I use them with my hi-flow cat on the street and on my "off-road use only" header (without a cat) on the track. No Codes, ever. Just make sure your sensors are both in good working order. Good luck.
maxtierney is offline   Reply With Quote
Old 10-09-2015   #7
lowlife9's Avatar
yeah buy a Megan cell eliminator like this one with a bend so theres more room for the wires http://www.ebay.com/itm/Megan-Racing-Mechanical-O2-Fix-Version-2-/361386689295?hash=item542453430f
lowlife9 is offline   Reply With Quote
Old 10-09-2015   #8
thank you everyone who has replied, my next question is , which header is the best one to buy for fit and finish also for attaching my oem exhaust pipe, thank you again
Old 10-14-2015   #9
EM2ti
maxtierney's Avatar
Not a lot of choices for when it comes to D17 headers. Megan, OBX, eBay are the typical economy routes. You can get custom headers (or the knock-off) from Bisimoto, PLM, KTeller, etc. Or the tried and true, DC Sports 4-1 (HHC5019) or 4-2-1 (HHR5019). I have both.
Old 10-21-2015   #10
Pier7866 is an unknown quantity at this point
The best I believe is the magnaflow manifold catalytic converter and is literally the same price as oem heard a lot of good things about it though. Hope this help.
Pier7866 is offline   Reply With Quote
Old 10-21-2015   #11
Quote:
The popular one back in the day was the kamikaze header. Still rocking one (ceramic coated) to this day
Old 10-21-2015   #12
lowlife9's Avatar
ive been using Megan for last 6 years the only issues are the supplied bolts are rusted to **** and most likely seized and the subpar gaskit that came with it other then that no problems. if i could go back i would have spent the extra money on a DC ceramic coated header.
Old 10-22-2015   #13
Mad Dog Tannen's Avatar
Most headers come with both bung holes, check before purchasing.
You may not need the emulator (spacer) for the downstream o2, every car/header/ECU is different. I say install a header with both sensors and get a emulator only if it pops a code.
Don't throw parts at, it unless they are needed.
If you want it Cali smog legal, then Magnaflow offers a high flow manifold/cat for about $500 (OEM is about $450).
Mad Dog Tannen is offline   Reply With Quote
Old 10-28-2015   #14
EM2ti
maxtierney's Avatar
Bad News - Technically, the only legal cats in California are OEM or OEM equivalent.
Good News - Nowadays, 2000 and newer vehicles only have to pass a visual inspection for the cat, but if it doesn't look stock, it won't pass (unless the tech is clueless or just doesn't care). Even if you do pass a visual, the sound/smell would set off alarms. You'd only pass a smog, only if the high-flow was freshly installed (maybe). They get worse after some time. High-flow cats degrade pretty fairly quickly/significantly. There's barely enough material to effectively convert/burn-off gas when they're new. They deteriorate at a much faster rate than stock. I've been running a Random Tech Hi-Flow for about four years. Nowadays, it's pretty much just a straight pipe. I always swap back to stock for my smog checks.
Old 10-28-2015   #15
The $500 Magnaflow high flow manifold is the only Cali legal high flow option that I have found. I had a magna flow in my other car for a long time without problems, until I ruined it by driving a long distance with a misfire.
Old 10-28-2015   #16
Allow me to explain through interpretive dance
Or C.A.R.B. approved.
"49 state" cats are not approved for California.
ezone is offline   Reply With Quote
Old 10-28-2015   #17
The carb number also has to match for your vehicle, so don't try to get a carb cat off a chevy.
Old 10-29-2015   #18
lowlife9's Avatar
there was only one time i had an issue being catless when my usual place had a new guy that did everything by the book and crawled under the car i just played dumb when he told me there was no cat and i wouldn't pass. he ran the test and lo and behold i passed which he wasn't happy with but he let it slide.
Old 11-03-2015   #19
Quote:
Wow You pass catles?
What are you driving? Wolksvagen?
Thread Thread Starter Honda Civic Forum Replies Last Post
Honda Civic Ex 2001 oil leaking problem LionSpratt General Automotive Discussion 14 01-29-2017 11:07 PM
Hello from Oregon! CascadiaBlue Introduce Yourself! 11 04-18-2015 09:13 AM
San Francisco (San Jose) Bay Area Civic Owners! locozoko West 19 04-06-2002 09:00 PM
Does anybody know a cheap, good body shop? aZnVoYCe West 4 12-07-2001 12:41 AM
Need help! Magnaflow or Mozart (Konig) muffler? aZnVoYCe Basic Engine Performance 3 11-04-2001 10:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All Content Copyright 2017 CivicForums.com
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
