Exhaust Manifold Cracked! -- Advice?
Rep Power: 0 Exhaust Manifold Cracked! -- Advice?
I recently noticed that there's a small crack in my exhaust manifold. The car has been running normally, so I'm not sure how long it may have been like this. Link to photos: http://1drv.ms/1CNjfSO
Is this a serious problem? and if so what should I do to get it fixed. I read that I might be able to get a mechanic to weld it, is that worth it?
Thanks.
Thanks.
Re: Exhaust Manifold Cracked! -- Advice?
Weld or braze is cheap, and if it works and lasts a while, then great.
If it doesn't last, then it gets less cheap (replaced).
if your welding it, I recommend heating up the cast iron and slap a bead on it ....
http://www.lincolnelectric.com/en-us...on-detail.aspx
hayden55
07-08-2015 11:38 PM
fvckbg
07-07-2015 07:08 PM
