'02 Civic - brake reservoir cap arrow point towards front bumper, or cabin?
Old 04-13-2014
TrustyAutos's Avatar
TrustyAutos is an unknown quantity at this point
Hello.
The dealer did a mini-inspection on my newly acquired 2002 Civic EX.
The "inspection" said I should replace the brake fluid.
I won't pay them $90 to do it though (thanks to youtube!).
When I looked at the cap of the brake fluid reservoir, there's an arrow on top.
Initially the arrow pointed towards the cabin.
Now when I put the cap back on, it seems to me that it fits better if I point the arrow towards the front bumper. But this is 180 degrees from the way the dealer had it.
Which way should it point?
Thank you,
david
TrustyAutos is offline
Old 04-13-2014
Re: '02 Civic - brake reservoir cap arrow point towards front bumper, or cabin?
EDIT: Arrow usually points forward.
EDIT2: In your owners manual, I don't think it specifically says anything about the arrow.
I looked at an 02 owners manual on page 222-223 and saw no mention of the arrow.
Personally, I don't think it matters as long as it sits on correctly and seals.
ezone is offline
Old 04-14-2014
Stock 99's Avatar
Just an FYI. When you change brake fluid you need to bleed all the old fluid out of the lines as well. Brake fluid is designed to absorb moisture and as it absorbs moisture the colour of the fluid gets darker and darker. If you don't bleed that fluid out of the steel brake lines eventually they will rust through from the inside out.
I'm not sure what you did but this youtube DIY is instruction on how not to change your brake fluid properly......youtube....you get what you pay for
Stock 99 is offline
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
mattdoc
03-14-2017 12:10 PM
SQCivic
11-08-2001 05:56 PM
sonsonzai
11-04-2001 12:52 PM
Quick Reply: '02 Civic - brake reservoir cap arrow point towards front bumper, or cabin?
