Hid help!!!!!!
Rep Power: 0 Hid help!!!!!!
just bought a set of of angel eye halo projector headlights off Craigslist (right good idea NOT) they have h1 on the back and there's 2 bulbs in each housing no ballast or relay can someone tell me were to go from here what size ballast,good site to find or a way maybe to wire halogen bulbs up maybe
Prelude Owner
Re: Hid help!!!!!!
Check out:
www.theretrofitsource.com for relays and ballasts. You pick how many watts.
What year civic do you have?
Rep Power: 0 Re: Hid help!!!!!!
ok I just checked out the site now before I buy do I need a ballast for each bulb or is there a way to wire separate hi low beam I have 4 hid bulbs that I need wired up
Prelude Owner
Re: Hid help!!!!!!
Does your stock headlight look like this:
Yes you will need a ballast for each bulb, but you will only power your actual headlight with the ballast. Your parking light is not run off a ballast and should not be HID.
Do the headlights you have have projectors with a high beam solenoid?
yea that's what my stock headlights look like my side markers aren't hid but the headlights I want to put in are duel halo with one projector and the other clear both with hid
Rep Power: 229 Re: Hid help!!!!!!
I have a set from the retrofitsource for over a year now..not a single porblem with them..buy with confidence. They are more money than fleabay, but the qaulity is alot better.
Super Moderator
Re: Hid help!!!!!!
a.) 2 standard projectors with halogen bulbs for brights
b.) 2 standard projectors and 2 bixenon projectors (they mechanically drop the cutoff so that your projectors shine farther when your brights are on).
c.) 4 bixenons!!! That would be pretty badass but a little bit trickier to wire. It wouldn't be TOO hard though.
+1 to 04 Honda Civic. TRS products and service are great!
Received 1,146 Likes
Rep Power: 485 Re: Hid help!!!!!!
*ahem*
H1 hid bulbs aren't quite "stuck it in and go." Last I checked, you have to bore out the bulb opening in order for them to fit. Ditch the halos, grab a morimoto retro "kit", and slap them bishes in your oem headlights. Easiest retrofit out there. If you wanna retrofit the halos, you're gonna have to put a bit (read: a lot) of creativity into msking the projector sit happy
Super Moderator
Re: Hid help!!!!!!
As far as wiring is concerned, if you have a good harness it should plug right into one of your headlight connectors, and your ballasts will be connected to the harness. Power will be drawn directly from the battery to the harness as well. I'm not sure how you would hook the brights up (I'm experienced with the bi-xenons, which are controlled through that harness as well) but you can sure do some homework! :-)
Prelude Owner
Re: Hid help!!!!!!
**The wiring is different from 01-03 to 04-05. 01-03 used a single bulb for both high and low beam while 04-05 used 2 bulbs, one low and one high.
No. It sounds like he got projectors for 01-03. All aftermarket projector headlights out there for 01-03s split the headlight from a single h4 to (typically) 2 separate h1 bulbs.
Also, you got the facelift year wrong. 01-03s have an h4 hi/low. 04-05 has a 9006 (or was it 9006 and a 9007) for each high and low. 03 is when the cluster and suspension crash bolt diameter changed.
TheRiddicles
09-21-2015 01:28 AM
MamaBear2015
09-04-2015 09:04 PM
