Installing K&N Air Intake on 03 civic
Rep Power: 0 Installing K&N Air Intake on 03 civic
I am getting ready to purchase a K&N Air Intake System for my 03 Civic EX coupe. How difficult is this to install? It looks fairly simple online but I do not have much experience installing aftermarket parts. Thanks for the help.
Whachya lookin at?
Rep Power: 288 Re: Installing K&N Air Intake on 03 civic
A lot of thought goes into the OEM intake system. If you look it is quite complicated and much more expensive to create than a short ram intake. If a short ram or cold air intake truly were a better product, every car manufacturer by now would have implemented it with a sound resonator built in. Unfortunately where pretty much all aftermarket intake systems fall short is the turbulence control that is built into the stock intake. This is also where most of the research comes into play with OEM intakes.
Once there is turbulence inside the intake it prevents your sensors from working properly and could actually cause the engine to run rich or lean, shortening its life span. By how much? I can't say. This information is ESPECIALLY true on turbocharged engines where the A/F mixture is even more crucial, but it's also very important on our cars as well.
There are companies out there that make honeycomb filters for aftermarket intakes that will decrease the turbulence in the intake but they scare me because they tend to be plastic. If a piece of this gets sucked into the engine there could be some pretty severe damage.
Here is a pretty good read on intakes as a whole, just ignore all the subaru references:
http://www.mysubie.com/faq?id=16
More good stuff:
http://www.cobbtuning.com/Technical-...es-s/70677.htm
Take it for what you will but aftermarket intakes also don't filter nearly as good as a paper filter. Lemme Explain. The technology used by aftermarket intakes is generally derived from race cars and cars that get their engines rebuilt very frequently. This creates more airflow, more power, and less filtration. One of the biggest selling points of intakes is "Cold air", and "High Flow". But realistically. To achieve more air there has to be compensation somewhere, which is with the filter.
K&N Will flat out TELL you that their filters are not as good as OEM paper filters. I can't find it now but here:
http://www.knfilters.ca/77series.aspx
My favorite line:
The oversize air filter also captures more dirt increasing the service life before each cleaning is required (up to 100,000 miles).
This is referring to other K&N filters, NOT an OEM paper filter. But.. If you are trapping more dirt, doesn't that mean the filter will need to be cleaned more frequently... or am I just a dumbass?
Don't believe what is written on websites from the manufacturers. A lot of their information is misleading. I found this while searching, it seems informative:
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
There are even more downfalls to K&N filters however. If you run cold air there is always the risk of sucking up water and hydro locking your engine. Then you have to keep in mind that aluminum pipes tend to get soaked with heat relatively fast which will negate any gains you might see from an intake. This is especially true over long drives.
So.. Keep this in mind when looking for an intake. There is only 2 REAL reasons to buy them.
1. Looks
2. Sound
More good stuff:
My favorite line:
1. Looks
2. Sound
More good stuff:
My favorite line:
1. Looks
2. Sound
More good stuff:
My favorite line:
1. Looks
2. Sound
But, I have to agree with you on the aftermarket intake systems. There are too many unknowns with buying one for such little gains (assuming you don't decrease in horsepower by installing an aftermarket intake...). They cost too much for such little gain. I love to see the outrageous claims on the websites. You'll gain xxx HP. Yeah, sure will. I'll keep my car stock.
To the filter argument. I've been reading about K&N for years. I have been using a K&N for years. I did some of my own testing with used oil analysis (UOA) and have found that the K&N did just fine. That was on a brand new Dodge Ram that I owned. I have one in my Civic and am doing UOA's every oil change. If something on the UOA indicates that the K&N isn't performing well, I will go back to OEM.
Whachya lookin at?
Someone says air intake system I think they are replacing the intake not just filter. It's up to you but a paper filter will do the exact same job the K&N will and even better for a fraction of the price. I don't recommend them to anyone.
If someone is going to sell the car, then just use paper. I agree with that.
Whachya lookin at?
Alright. We disagree on the filtration however. I think a paper filter performs much better than a K&N. You think they are at par. There is no way we can prove it either way so let's just agree to disagree Also with the K&N you need a recharge kit. It's messy, and you lose your car for a period of time to let it dry. I just don't personally like any of it.
Rep Power: 232 Re: Installing K&N Air Intake on 03 civic
i never recommend K&N oiled filters but there hybrid filter is a re-branded AEM dryflow. i always recommend AEM plus there dryflow cone filters have a built in velocity stack to reduce turbulence.
SneakerPimp
Bolt-on Engine Performance
11-04-2001 01:12 PM
