What causes headgaskets to go so easy on 01-05 civics?
Rep Power: 0 What causes headgaskets to go so easy on 01-05 civics?
As the title states what are the causes (besides overheating or neglect)? I curious if it was lack of flatness on the block or head or the gasket it self. The reason I ask is mine popped and while I could do it I simply don't have the time. Luckly I have friends that work at old honda I use to work at so I'll have them do it.
If replace is the "problem" fixed or will it go out just as quick as this one did (104k)? I've seen alot of hondas with over 200k with original headgasket. Honestly don't want to have to put up with this again. Is it a problem with the motor it self or just the gasket material?
Re: What causes headgaskets to go so easy on 01-05 civics?
Some do, some don't. It's just something they do, a known problem area. Deal with it. Fix it right.
IMHO, I think that using TTY head bolts with the MLS gasket would have been a more durable setup.....but I'm not one of those high-paid engineers so WTF do I know?
I looked at an 04 with 97k today, looked like it has the problem too. Reservoir was overflowing and the radiator was low.
Prelude Owner
As far as I know mine is original. I'm second owner and first owner had dealer records. I'm sure maintance plays a role in it.
I'm at 170k miles.
It will go on my way to work tomorrow now that I said that!
I'm at 170k miles.
Rep Power: 0 Re: What causes headgaskets to go so easy on 01-05 civics?
Whachya lookin at?
Rep Power: 288 Re: What causes headgaskets to go so easy on 01-05 civics?
I think it's a combination of things... honestly.. But lack of maintenance or failure to recognize a small problem causes 90% of them to go. The other 10% could be the bolts, or the incredibly high engine revolutions on the highway for extended periods of time.
I got the OK to make the inspect/diag today on the 04, it's breached between the combustion chamber and water jacket on #2. Got the OK to do the job too. It's apart and waiting on gaskets to arrive right now.
What sort of maintenance do you think could be done to avoid this extremely common issue? Many of these crapped long before the first coolant service was due.
Whachya lookin at?
Some type of failure usually leads to a blown head gasket. Every head gasket I've seen go on these usually has some other issue (Stuck thermostat, air in coolant system from work done, etc.) The list is endless but usually there is an underlying problem. Even when mine went my thermostat was leaking, I had air in my coolant system which caused overheating which caused my stupid head gasket to go
Whachya lookin at?
HOWEVER I should add you see a lot more of them then I do.. so.. I'm not going to disagree with you hahaha
95% (or more) that I see have the head gasket itself as the underlying cause. JMHO, YMMV.
7th Gen Civic DIY Enthusiast!
Rep Power: 161 Re: What causes headgaskets to go so easy on 01-05 civics?
I'm no professional mechanic or engineer, but if I had to take a guess, I think that maybe there's a little better burn going on in these engines than in previous generations for EPA crap and also the sealing material on the head gasket around the fire ring can't handle the heat and over a period of time slowly wears away. Just my .02.
Are they still popping even after being replaced? (if so, I'm going to get rid of it)
If this was indeed true mine wouldn't have failed. I'm on top of my maintenance. Take care of car and the car will take care of me.
I'm a mechanic, and I have just enough engineering in my background to be dangerous and annoying.....But I think what everyone wants here is a failure analyst. I'm not one. That's pretty much it. Design weakness IMHO. I don't think I have seen one fail a second time for without another primary cause.....but then you have to figure I work for a dealer. By the time a car is old enough to have the head gasket failed twice, it may no longer come to our shop. In fact, 7th gens are getting few and far between as it is already here.
Whachya lookin at?
Hmm.. these cars are interesting. They have high failure rates on two major things. Head gaskets, and automatic transmissions. To me that's a major problem and a fail for Honda.
The Accord V6 still has a normal automatic trans.
Pulled the head took 2 hours and went a head and took the timing belt off. I've read some people don't do it. It's sad to say but this is my first time doing a headgasket when I've been turning wrenches for almost 10 years. On a civic atleast. I don't see any real signs the gasket is bad. However the exhaust valves on clyinder 3 were a lighter color than the rest (brownish/white) while the other ones had clear carbon burn. I think it is safe to say this was the trouble cylinder. I put wd40 in the clyinder wall (2 of them) to prevent rust until I can get parts tomorrow and seal the head.
Do you guys normal keep the intake manifold and exhaust manifold on the head because I did.
Be careful when you set it back down, there are valves open and they bend very easily. I hope you didn't set it flat on a bench.
No issues that I have seen yet. Can't tell you about the rest of the country though. If the problem was small, it's almost impossible to see where the failure is, even when you know which cylinder was the problem. MLS gaskets just don't show like a composite gasket can. I remove it all because IMO that makes it lighter and less awkward, and I take the head all the way off and measure for warpage and have it machined if necessary.
http://img.photobucket.com/albums/v5...ps5eece6ee.jpg
05 started coming out in late 3rd quarter of 04 and 04's started to come out in late 03. The change didn't take place until 04, thus most of the models that have the issues corrected are the 05's.
And most importantly, how many months (rough time frame) would you say from when a car gets built in the factory to when it gets to the dealer?
My auto trans was delivered to the dealer in May of 2004. So if the 04 trans started in late 03, im guessing im safe to say that I have the 04 fixes?
Thats why im curious how long it takes from when a car is built to when it hits the dealer and if the trans put in is at the beginning or near end of the factory building process. Since may and 3rd quarter are relatively close in time, im wondering what the odds are that i got the fixes in mine.
I do know that the serial number on my trans wasnt listed on the Honda TSB where it listed all the serial numbers of the trans with the faulty clutch packs. Mine wasnt on it.
Whachya lookin at?
^ Based on what he i saying you don't have the fixes. Cars that were delivered in September or October on in 2004 had the fixes. I'm not exactly sure what he is talking about though because I don't know anything about the automatic transmission. Not sure what the fix was. I do know however that the internal filter is the biggest cause of failure on these transmissions. The filter gets plugged up and because it can't get changed eventually causes the tranny to implode. This wasn't fixed in 05, but they may have found a workaround.
