Jerking on 3rd and 4th gear.
Rep Power: 0 Jerking on 3rd and 4th gear.
Hey guys,
I have a 04 civic EX. So recently I've been having some intermittent jerking on 3rd and 4th gear. It doesn't happen on neutral, 1st or 2nd gear. The jerking happens most when i accelerate. When I let go off the gas a little bit and accelerate slowly, it stops.
This all started after i removed the battery cable for cleaning. I thought it was the ECU at first so i tried resetting it and no luck. My car has 100k on it and i was about to do the timing belt, but this started happening. Could it be the timing belt and the timing is off?
I also checked the vtec solenoid, but it was good. I'm bout to check the fuel press. to see if can be a fuel supply problem. Other than that any suggestions what else to check?
Thnx guys!!!!! Any input is greatly appreciated
Re: Jerking on 3rd and 4th gear.
Hey guys,
leave that stuff for the bedroom!
(sorry, i couldnt resist)
Received 1,440 Likes
Rep Power: 338 Re: Jerking on 3rd and 4th gear.
loss of power? old air filter? slipping clutch? etc, etc
sesi
10-01-2015 02:03 PM
ThatGuy913
09-28-2015 05:35 PM
Touge
09-23-2015 10:51 PM
BBrosario
09-17-2015 07:51 PM
