Has anyone bought Greaseable CV Joints?
Rep Power: 0 Has anyone bought Greaseable CV Joints?
Well hello there, I already know i have a bad passenger side CV joint, and eventually will just replace the whole axle, and will do front wheel bearings and ball joints while im at it.
Was just wondering if anyone has found any place to buy greaseable CV joints, as well as greaseable ball joints?
These ungreaseable things are junk.
1 Post
Rep Power: 176 Re: Has anyone bought Greaseable CV Joints?
Never even heard of greasable cv axles. Ball joints yes. If you actually grease them greasable wins hands down. If you are like most people and don't grease em like you should, non greasable wins. Wheel bearings are a pain, you have to press em out. If you are pulling the knuckle off the strut to do wheel bearings you should plan on getting an alignment too.
Busy Speeding!!
1 Post
Rep Power: 169 Re: Has anyone bought Greaseable CV Joints?
I bought greasable ball joints but if you look at your car the top of the ball joint is really close to the axle. The grease end won't fit on there. I had to ghetto rig something up
Rep Power: 0 Re: Has anyone bought Greaseable CV Joints?
Well I'm kinda like a Maintenance freak, On my truck which has greaseable everything except U-Joints I grease it every 3k when i do oil changes, it only takes 5 mins, I can't stand people who don't maintain things that cost thousands of dollars, its so simple and costs less money in the long run.
Wish the civic's suspension had grease fittings on all the pivot points/joints, would make the things last a lot longer.
1 Post
The thought still stands though, most people won't grease like they should. With that in mind it is in the best interest of car makers to just make them "greased for life", and avoid the people that complain that these things fall apart before the warranty is even out. Usually the only time anything gets greased is at quick lubes. Enthusiasts, like a large percentage of forum stalkers are, are actually a small percentage of the general population. I can't change my own oil cheaper now, but still refuse to let some minimum wage earner touch my high dollar vehicles. Yes, those guys that actually do care and do good work are out there, I was once one of em, but they are not at every shop.
Greasable CV Joint?... Well you can Re-Pack em if you want... thats usually only done if the joint is any good, and you just have a torn Boot... they are all "Greasable" but you only really do it if you tare your CV Boot, and replace it with a new one (PITA) to the best of my knowledge anywho
mistermenphis22
04-03-2016 08:06 AM
hans.pcguy
07-12-2015 12:19 PM
pheaton
05-04-2015 08:26 PM
